A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
239вопросов Показать все
A quarter of my screen just died today
I just want to share my suffering with other Apple fans. If you have some advice or links to related topics please share. When I woke up today, everything worked fine. I watched some YouTube videos, went to the gym and when I returned back this happens!
https://giphy.com/gifs/vvaqMMjnrv70WdEXR...
Unfortunately, my MBP 2016 is just out of warranty. Bought in December 2016 (in Czechia, EU we have 2 years warranty).
I am still confused about why the !&&* this happened. I had no issue before with my MBP before except keyboard which I learned how to clean every week with pressured canned air.
I have never smashed that screen, hard closed the lid or dropped the MBP on the ground. It just happened after 2+ years of daily use.
I love Apple but I am p***** that I had to use warranty service 2 times for broken keyboard and then when the device is just out of warranty the screen breaks. This is not how I imagine the built quality of the device that cost me ~$2400.
I am not sure if I will be able to repair it by myself from what I have found the repair cost will be about $500-$750. I wish there was
I really needed to share this with somebody, I hope you guys will understand.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Wow that’s unfortunate. My 13” 2016 occasionally has glitches that look like that, only in smaller sections and very briefly, so it doesn’t really affect anything I do yet. But I suspect it’s getting worse :(
My assumption would be it’s something to do with the “flexgate” issues plaguing the 2016-17 models. My only hope is that Apple gets hit with some class-action lawsuits because their behavior recently is honestly unacceptable. They’ve been shipping defective products and turning a blind eye to the people affected. I’m definitely not looking forward to my MBP developing the same issues you’re facing.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Good luck with that, hopefully, you will avoid full thick black line over screen.
My screen was 100% ok before that a I never had even a slightest issue and it just happened. It really surprised me.
I know that I will pay money for repair but I will at least try to call Apple support on Monday to raise at least a little awarness about this issue.
из
You're right! The issue is the ribbon cables in this case it's the video lines are damaged.
So far a bang on the clutch cover has been the cause that I've seen. But its also likely the cables over time also breakdown when the lid is pushed back.
Sorry to say you'll need a new display assembly to fix this. Once you do try not to bend the display beyond 100 degrees.
из
Добавьте свой ответ
Ondřej Ševčík будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 118
