LTE CPE Stuck Problem
Dear
I am working in a small orgnization where we can repair WiFi Routers, LTE CPE’s & Wiamax CPE’s. last couple of days i am facing a problem of Stuck/Freezing problem the CPE is LTE wltfsm-136acn. its Power and LAN LED is stuck and no operation will be done. if anyone can help me.
Это хороший вопрос?
Счет 0
2 Комментариев:
Hi Ahmad
there are many reasons why it fails....
i suppose when you power up.. the LED stays lighted up for all?
sometimes could be hardware issues....
corrupted flash / loader....
suggest you to open up and share more pictures to us
из
Hi,
Did you try pressing the "reset" switch on the back of the unit (between the Power On/Off switch and the LAN socket) to see if this resets the router?
из
Добавить комментарий
