The Motorola Moto Z Force (XT1650) is an Android smartphone developed by Motorola. It also is known as the Moto Z Force for markets outside the US and has been available since July 2016.
31вопросов Показать все
Replacement screws for display assembly.
So, I started to work on replacing my phones battery, and I got all of the screws out except for one, which decided to strip on me, I’ve already ordered the extractor set, and I’m wondering what kind of screw to replace it with, or if I can go without one screw.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
if all the other screws hold the component in place decently then you should be fine like i there were 4 screws and you extracted 3 , you would be “ok” unless is less than 3, then i suggest you try to find the screws
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
there were six screws, so i will just use five then.
из
oh, well then you should be fine
из
Добавьте свой ответ
Patrick Hankins будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 57
