The Canon PowerShot A2000 IS is a 10-megapixel point-and-shoot camera with a 6x optical image-stabilized zoom lens. It was originally released in 2009.
What to do for locked card warning(any sd card
what do i do if my camera says card locked ,no matter what card I put in? I have checked the tab on the chip and it is'nt that.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
Check that the card is seated properly inside the camera. It could also be possible that the memory card is damaged or defective, so try swapping in a different Secure Digital card. There is a little metal flap inside the card chamber that detects the lock position for the card. See if that is properly engaging. Sometimes you can re-position it with a paper clip etc. Here is a link to it http://camerarepair.blogspot.com/2009/07... Also, of course, check your user manual to make sure that it is not in the settings of your cam ;-) Good Luck
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
the second tip was very helpful you'r the first one guiding it after searching an hour for this problem thanks
из
Hello!, I have the EXACT answer for you. I also own the same camera. Watch this for help:
https://www.bing.com/videos/search?q=unl...
I actually figured how to unlock my sd card before i watched the vid!
Счет 0
Добавьте свой ответ
valworley буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 2,272
