Replacing Thrustmaster Warthog toggle switches?
I’m using the Thrustmaster Warthog Joystick and Throttle. I have had them for at least 8 years with no major issues. Lately a couple of the toggle switches have ceased to function properly and I’m thinking of a DIY replacement.
# Toggle switch on the left-hand throttle control. 3-position - fwd, center, back. After checking Amazon for “electric toggle switch” I believe it’s do-able.
# Toggle switch on right-hand throttle control, right side, grey plastic cover (immediately above red plastic toggle). Not sure about this one although it appears similar to #1 also).
  1. Any advice/guidance before I try this is appreciated (i.e. can I assume the toggle switches are similar to; https://www.amazon.ca/Haobase-5Pcs-3Term...
  2. Thanks in advance.
Это хороший вопрос?
Счет 0
Добавить комментарий
