iPhone 7 rear camera and flash not working
my iPhone 7 hard dropped from running bike ,
then after i got below issues
1) wont turn on ( Power IC replaced - Working fine)
2) audio prblem ( Audio IC replaced- only headphones not working charging works fine)
3) screen totally damaged ( new screen replaced)
4) Rear camera and flash not working ( after replaced U2501 ic also not working & also checked with another camera not works ) showing only black screen
i fixed all issues except rear camera , even after replaced U2501 ( CAMERA IC ) Problem was not fixed front camera working fine
kindly suggest me best solution to get my camera back to works again
Thank you
Это хороший вопрос?
4 Комментариев
Could be main board damage (smc was knocked off by drop or something along those lines) or the connector on the main board was damaged or if you're frame is bent or damaged it could be shorting out.
из Sean Parrish
I’m guessing it’s CPU Issue
And compute benchmark score value is zero
из feroz_khan77874
Well it's probably main board not CPU. If it was CPU the odds of it booting is so low. Probably time for a new phone.
из Sean Parrish
You are right but I spent more than $200 for this minor repairs
That’s the reason I can’t go for another phone
If I got solution this issue will fix it nd sold
Kindly tell if any jumper option to get fixed this issue
из feroz_khan77874
