1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
What kind of switch is the on/off button
I have broken on/off switch what kind is it? SPST, Normally Open, or what? I see the two little wires that come from the back of the switch, Just wanted to replace it with common stock items.
Thanks in advance.
Это хороший вопрос?
Счет 0
1 Комментарий
Thank you, I thought it was a NO, but since it had broken off, It would come on as if power had been out and had then been restored.
из
Добавить комментарий
1 ответ
Выбранное решение
It’s a simple push-button under spring pressure normally open.
If you can find the Bottom Housing Apple P/N 076-1210 it comes with the button.
Here’s one source Bottom Cover for Mac mini Early - Late 2006 & Mid 2007 It’s only $5.00 How can you go wrong!
If you live in the UK or EU Bottom Cover for Mac mini Early - Late 2006 & Mid 2007 It’s a bit more $25.00 ;-{ Maybe you can haggle a bit.
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
I have several SPST and a handful of NO's regular round red push button types, so I have one for free.
из
You need a momentary contact switch (push button with spring) not a SPST
из
Добавьте свой ответ
Michael Inman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 379
