Released September 2016. Identified by Model No. SM-G610
164вопросов Показать все
Why is my back button not working
What causes some keys not to work sometimes? I discovered the return/back button on my phone wont respond to touch often times. This is frustrating because it makes using an app that requires a return function difficult.
Это хороший вопрос?
Оценка 6
3 Комментариев
The same with my phone return button didn't work but when I tried to reset it works it features not the factory reset it work for several minutes only, then not working again, seems there's time elapse program to lock. I tried all options even the factory reset. The same happened working for several minutes only.
из
Can anybody suggest to solve this problem without going to any phone tech?
из
لقد سقط هاتفي مرات كثيرا علئ الارض
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Do you have a screen protector on the phone? If you do it could possibly just be a case of a bad cheap screen protector. If not it could be an actual issue with the buttons themselves. Or it could just be phone lag if they eventually do respond or if the phone freezes when you press them.
Hope this
Был ли этот ответ полезен?
Оценка 1
I had this problam too, when i opened the phone there was a little water damage.
Are you sure it does not have any water damage…
Оценка 0
My back button don't work at all
Оценка 0
Добавьте свой ответ
Chinwe U-O будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 20
За всё время: 5,658
