I replaced my phone battery, but now the screen is unresponsive. Help!
I have an iPhone 6s and I replaced the battery, but now the screen is unresponsive. All of the connections are secure so I’m not sure what to do.
Это хороший вопрос?
Это хороший вопрос?
Did you unplug the battery before you removed the screen cables? Battery should always be the first component to disconnect before any repair.
Был ли этот ответ полезен?
Check all the ribbon cables and ensure none of them are ripped or damaged, they’re very fragile. Then check all the connectors themselves for any bending or damage. When you connect the screen connectors, be sure to press in first on one side, then the other. Don’t press in the middle or they can bend. They should click in on both sides.
Then restart your phone, try a hard reset by holding the Power and Home buttons simultaneously for 15 seconds or so, that can occasionally clear up issues.
Unfortunately if none of that works, you might’ve really screwed up the screen somehow, the only fix is probably going to be a replacement.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 28
