Can I use the display unit of the Surface pro 5 for pro 6?
Hi,
can i use the Display of the pro 5 to fix my shattered Pro 6 Display?
Это хороший вопрос?
Hi,
Это хороший вопрос?
No you can’t, the Surface Pro 5 and Pro 6 displays have different touch controllers and are not cross-compatible.
Был ли этот ответ полезен?
I have installed the pro 5 display on a surface pro 6 without issues. I’m not sure sure where you got your info from but they are 100% cross compatible.
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 26
За всё время: 1,828
1 Комментарий
I'm going to give a tentative "yes" with the caveat that I'm not speaking from direct experience.
Looking at pictures of replacement screens for both the Pro 5 and Pro 6, the cabling looks to be identical. The specs (resolution, physical dimensions, etc) for the screens are also the same. I also found part number "LP123WQ1 SP A1" being sold on eBay as a replacement screen for the Surface Pro 6 *AND* the Surface Pro 5.
из Steve
