Repair guides and troubleshooting for the EasyNote TJ65-CU-030GE, a 15.6" budget laptop by Packard Bell.
No powering on, not even a light
EasyNote Te
Have tested the power cable (friends) so not the cable’power.
Have taken the battery out, held switch down for 20 sec’s then plugged in the cable, still no joy, not even a light.
Это хороший вопрос?
Счет 2
1 Комментарий:
it may be a software or internal computor issue try go getting it repaired by a person licened to do so to avoid damaging your pc any further
из
Добавить комментарий
3 Ответов
This is internal damage, The Display Cable might be loose or damaged, you will probabally need a professional to remove the screen. Its easy to put the cable in but it is also very easy to destroy the cable.
Был ли этот ответ полезен?
Счет 0
Yes i did so,but still is not powering or showing any light
Счет 0
I've checked that and it's still not on
Счет 0
Добавьте свой ответ
Alan Barber буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 18
За всё время: 2,491
