Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577вопросов Показать все
What's the secret to getting the replacement screen to stick?
I’ve replaced dozens and dozens of Samsung screens and have ONLY have a problem with the S5. I have one here with a broken screen. I removed the screen and cleaned the frame absolutely spotless. Not a single speck of old adhesive or glass or oil or anything on it. I even stripped all the electronics off it and put it in my sonic cleaner for good measure. Look at it under a microscope and there’s not a single dot to be found.
The frame and screen are both arrow-straight, no warpage whatsoever.
I apply the new adhesive to the screen, make the connections, then press the screen to the frame. It settles in nicely, as expected, but then a few minutes later it starts to lift. After maybe 10 minutes I can stick my fingernail underneath and lift the screen off.
The adhesive is crazy aggressive; if I touch a tool to it, for example, the tool requires a bit of strength to remove itself from the adhesive. It also grabs onto the phone glass like nobody’s business so I know it’s not the adhesive. It just won’t grab onto the frame.
I’ve tried putting the phone on a flat surface, screen down, with a weight evenly pressing down on it, overnight. Half an hour after releasing the weight, the screen is lifting. I’ve even tried heating the phone and adhesive and pressing it to the frame with spring-loaded clamps until it cools. That lasts about 20-30 minutes before the screen lifts.
Это хороший вопрос?
Оценка 0
2 Комментариев:
Not interested in a hack.
из
Добавить комментарий
1 ответ
It sounds like it is bad adhesive quality. Try this one. Galaxy S5 Touch Screen Adhesive
Galaxy S5 Touch Screen Adhesive Изображение
Продукт
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
As per my post, it's not the adhesive quality. It's CRAZY aggressive on every surface EXCEPT the frame. It's almost like the frame is Teflon coated. And it's not just THAT adhesive; if I take a bit of 3M adhesive tape and stick it to any part of the frame, it sticks hard. But if I stick it to the part of the frame that the screen sets against, it peels right off like it was nothing. I've already tried three different adhesives.
Take a look at the first pic I posted. See the gray kinda-patterned part of the frame? That's where it doesn't stick. Anywhere else in there it sticks fine.
из
Добавьте свой ответ
Steve будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 122
