This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
355вопросов Показать все
Fujifilm Instax Mini 8 polaroids coming out blurry
hi guys my polaroids are coming out very pale. the black is not very vivid, ive tried playing around the modes too
either its too dark or its too light for the same image.
does the film expire? and does it affect the image quality?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
if the film has not been stored in a stable environment ie too hot or too cold this can cause the film to produce images that may appear washed out or pale. This effect may also happen if you are shooting photo’s in very hot or very cold conditions.
If the image is blurry you may be too close to the subject; these cameras have a small range for focal distance at the close up-something like 45cm-1m, check you have the right setting for close up or long distance and vice versa.
Overly light photo’s generally mean it has been overexposed (too much light or too long an exposure). Check the door is closed fully and not leaking light on the film. Expired film may produce faded photo’s too.
I’d try a new pack of film, be careful when loading it, and see if the same photo results.
Good luck
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Sukeerti будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 25
За последние 30 дней: 70
За всё время: 9,358
