The Incanto Classic is a fully automatic espresso machine designed by Saeco.
10вопросов Показать все
Can I change the panarello wand that came with the machine?
Hi,
Wanted to know if I can change the panarello wand that came with the machine because I had lost one of its parts(which is no longer being manufactured) and one of the o rings in it shoots off when steaming. For everyone not familiar with this machine it doesn't have a normal steam wand, you can search it online.
Please specify with details about alternatives
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
I think this is the part you are looking for:
https://www.saecoparts.com/product_p/ac3...
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Hi @mayer ,
I thought that it might be this one, but the OP's ".... it doesn't have a normal steam wand..." put some doubts in my mind with regard to the proviso in the part info "Saeco Incanto, only models with a 6 mm steam pipe at the housing front."
Cheers,
из
@jayeff I don't know enough about it to really know. The link I gave has a whole list of parts in the left hand column.
из
Добавьте свой ответ
Moshe Dgani будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 9
За всё время: 274
