Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214вопросов Показать все
Custom screen adhesive strips not sealing.
Replaced screen using custom adhesive strips & heating pad… pops loose. Bought second set of strips & tried again… still pops loose in the middle of two edges.
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
First things first, make sure the aluminum chassis is straight and not bent.
Buy a roll of Tesa 61935 adhesive from reputable vendors like iFixit, this tape is far better than 3M or ”red tape”.
Tesa 61395 Tape
Tesa 61395 Tape Изображение
Продукт
Tesa 61395 Tape
$5.99
Был ли этот ответ полезен?
Оценка 0
Agree with @ samy , as well before applying new strip, clean frame with ipa to remove any skin oils or adhesive leftovers. After applying strips and sticking screen on , add some books all over the ipad and leave it for at least several hrs in room temp. Adhesive strips needs some time to make a good bond
Оценка 0
Did the ipa & books technique. However, I see now that the careful straightning of all edges & verifying (before reassembly) is essential for a good seal.
Оценка 0
Добавьте свой ответ
Weyland Wong будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 100
