Узнайте о навыках, которые могут понадобиться вам для ремонта вашего устройства.
Non-ESD mat, used with a ESD mat.
I recently bought a silicone soldering mat that has notches and grooves and it really helps with organizing my work space during projects (mostly phone repairs) . But I did some research on the mat and found out it was not ESD safe. So, my questions is that if I did buy a ESD safe mat, would it be okay to use the non-ESD safe mat on top of it.
In other words, ESD safe mat on the bottom, and silicone non-ESD on top. Would there be any static electricity generated.
Thanks, for the help. New.
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sadly you still run a risk even when you have an antistatic mat under it.
As an example if you take a ballon and rub it on some cloth so it builds a static charge. The charge is strongest at the location where you rubbed.
Why don’t you use some anti-static spray on it before you use it to be safe.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Juan Lopez буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 49
За всё время: 767
