The Samsung Galaxy S8 Active can be identified by model numbers SM-G892A (AT&T) and SM-G892U (T-Mobile and Sprint) and was released in August 2017. The Samsung Galaxy S8 Active is an Android smartphone produced by Samsung Electronics as the eighth generation of the Samsung Galaxy S series.
25вопросов Показать все
water damaged donor phone
ok so my s8 had a cracked scree kid dropped it down the toilet and bingo phones dead so my question is if i order another s8 with a cracked digitizer can i use the digitizer which is not cracked from the water damaged s8 as a replacement
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
In theory yes, in practice i wouldn't unless i can ensure no corrosion damage to connection terminals. Depending on your cost might be worth it to test.
New screens and digitizers I've seen are ranging from 50 (dont trust) to 200. So you always have another option.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
the_number1pikey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 92
