A 32-bit fifth-generation video game console that was first released by Sega on November 22, 1994 in Japan, May 11, 1995 in North America, and July 8, 1995 in Europe.
Game Disc Reads as CD, what should I do? please help
Every time I turn the console on WITH a game in it, it reads the cd as if it was an audio disc. It says its "checking disc format" then after it seems to attempt a load, it just stops and the cd ceases to spin.
Это хороший вопрос?
Счет -1
2 Комментариев
you sould try replacing the dvd drive and lazer
из
Why would you suggest that? How do you come to that conclusion and how is the person going to do that?
из
Добавить комментарий
1 ответ
Выбранное решение
First of you should make sure that your laser is clean. Also make sure you see your laser move properly. If the cleaning does not work (some people use a commercially available laser lens cleaning CD) you should start thinking about disassembling your Saturn. Here are some really good instructions. Once you got this accomplished, you will find a little orange "dial" which is actually an adjustable potentiometer. It is just above the cable that connects the laser assembly to the circuit board. When you turn the dial counter-clockwise, the laser will seem to get dimmer, when you turn it clockwise you will notice that the disk/drive will start spinning. (here is a video to help you with the laser repair) That is where I would start. OF course, make sure that you MARK THE SPOT where you start from. MARK IT FOR SURE so that you do not lose the starting point. But, start cleaning your laser first. Good Luck.
Был ли этот ответ полезен?
Счет 4
Добавьте свой ответ
elijah hewlett буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 5,180
