Screen not turning on but fans do
Computer doesn’t turn on, shut off as I was using it, screen doesn’t turn on or work, after pressing power button, fans turn on and speed up to jet mode but nothing on screen.
Это хороший вопрос?
Это хороший вопрос?
Sounds like a failed GPU. First think id do is test it on a separate monitor using the display port. If it shows a picture, then I’d start troubleshooting the display connectors and cable. Did it display any odd behavior before it shut down?
Был ли этот ответ полезен?
Throwing spaghetti at the wall to see what sticks is not very effective! Following a good diagnostic process is a lot better.
One good clue is the fans running at hight speed tells us there is an internal issue. SMC which controls the fan believes the system is overheating. So we need to get a better idea what happened to diagnose what area within the system needs to be looked at.
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 49
Can you give us some background on what happened. The more details the better!
из Dan
