Repair guides for Android smart phones manufactured by Wiko.
40вопросов Показать все
Stuck at FRP after factory reset and firmware system update
Wiko View Go
Model: W_P130
M_IMEI 357483090076511
S_IMEI number 357483090147130
History:
  1. upon power-on, phone stuck in boot loop.
  2. Factory reset performed
  3. Stuck at FRP with correct credentials for pattern and Google account
  4. System firmware update installed via pc <W_P130-V01.30.OPE-[Orea-8.1]-GBL>
  5. Stuck again at FRP with correct credentials for pattern and Google account
Should I send it to Wiko Repair Service? It was bought in Germay.
Any help and advice will be appreciated.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Thank you for the suggestion. However, if you read through my question you will see that I did all this without success.
And now I cannot even get into recovery mode, (by pressing vol. up and power), although I did this many times before the system update. Anyway, I don’t think I can use recovery mode for any solution to the problem.
Is there any possibility that the original problen <stuck in boot loop> could have been caused by a hardware malfunction? Maybe the phone got dropped or sat on.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Cheryl Carling будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 254
