Смартфон был выпущен 22 сентября 2017 года в двух модификациях: A1864, A1897, доступный GSM или CDMA модулями. Встроенное хранилище есть на 64 Гб или на 256. iPhone 8 Plus увидел свет в трех оттенках корпуса: золотом, серебристом и Space Gray.
678вопросов Показать все
iPhone 8 plus touch and freezing issues after screen replacement
I replaced the screen on an iPhone 8 plus with iOS 12.0 installed, a few days later the touch became intermittent, sometimes it works great sometimes and won’t respond. I updated to iOS 12.2 hoping to resolve the issue but the issue only got worse. screen sometimes would just freeze, I tab the messages app and it won’t respond after a few tabs now it works, screen is too sensitive, all apps could start to wiggle as if I touched and held an app longer that 3-4 second when in reality I barely touched it. I re-installed the original cracked screen and now it completely frozen, I installed a brand new screen and its still frozen. Please help!
Это хороший вопрос?
Оценка 1
2 Комментариев
Hi Owen, thank you very much for your reply!
-I installed 2 new screens and it turned on frozen, I restarted the phone and it’s still frozen
-I went ahead and re-installed the original cracked screen it came in with, it turned on but it’s still frozen, I restarted the iphone and it’s still frozen.
- I now reversed the first screen replacement and i’m back to square one where screen works when it wants to.
I wonder if iOS 12.2 has something to do with it?
из
It might. Try doing a full restore by going into dfu mode and restoring it via iTunes.
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Try replacing the screen. It’s probably just a faulty screen.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Have change the screen and the problem is still the same
My phone is hanging so badly
из
@beauty64950 start a new post with your problem. More people will see it.
из
i found this on my search, try it
'''iPhone 8 Freezing'''
Оценка 0
First remove the Home button flex and check that also cause such issues.This phone have 3d touch too this section makes such a problem.This will help you to solve that problem.
Оценка 0
Добавьте свой ответ
info будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 15
За всё время: 1,569
