Repair guides and troubleshooting information for microwave ovens.
759вопросов Показать все
Silence a microwave with simple panel
I would like to mute the beeping on a Sharp 75MR microwave. I have read that many microwaves can be silenced by holding the 1 or 0 button, or with secondary keys, but this has a very simple panel with only 10 minute,  1 minute and 10 seconds buttons, plus some pre-sets. Holding the number or pre-set keys does nothings, and holding stop activated the child lock.
It came with my employer-provided accommodation, so I’d rather not do something permeant to it, but I’ll disconnect the speaker if that is the only option. The manual has nothing on this topic.
Thank you
Это хороший вопрос?
Оценка 0
1 Комментарий:
Check the notch on the inside of the door. Does it beep when the door is open? Because it may not be reading the input signal
из
Добавить комментарий
1 ответ
take out the speaker on the board, if you know how to solder
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Green Fern будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 813
