Model No. A1367 / 8, 16, 32, or 64 GB capacity
915вопросов Показать все
White screen after replacement, but differently.
I have gotten the famous white screen after replacing the screen, but this time it's a bit different. The screen only turns on when iOS boots up, and never shows the apple logo at all. I'm completely stumped by it because the original screen works perfectly well, it's just in horrible shape. The replacement worked fine when I first installed it, and nothing I've done, not even a restore, will seem to fix this issue. I've even tried the power+vol up+home combination and got absolutely nothing. I'm worried I'll have to refund the screen. If anyone has a solution to this I would appreciate it rather greatly.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Did you try another new screen already?
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
@douglasvinicio I haven't had the money to order another one, so no. I just have the replacement I already purchased and the original
из
In base of my experience if your original one is working,your motherboard and FPC connectors are fully functional. So i would assume that is just buy and install a new screen to solve your problem.
из
Sounds like the screen may be faulty? Get the manufacturer to replace it and see if that fixes it :)
Оценка 0
1 Комментарий:
@ran9aa I will give that a go.
из
Добавьте свой ответ
SolarisTheBat будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 49
