4-дюймовый iPhone выпущенный в марте 2016 года на той же самой платформе, что и 6s. Доступен в серебристом, сером, золотом и розовом цветах с 16/64 Гб памяти. Модели A1662 и A1723.
Power Button didn't work (new case)
Hello together,
the case of my SE was broken, so I brought a new one and transferred everything in it.
After the first test I noticed that the power switch didn’t work. so I found out that the new button was different. In the picture you can see that the pin on the right side is missing and in the old case there was a cable.
I tried to install the cable in the new case but it didn’t seem right and also didn’t work.
Thanks for your help!!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
U can remove the pin using some thin pliers or something similar grab it in the middle and try to pull it up and out of that hole then push it into the new housing, the cable pictured I think is for grounding for the antenna or something like that, that wont affect the power button… the power button itself the flex could be damaged and in the picture it doesn't really look plugged in fully…
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
troche turnout буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 170
