The larger, fourth-generation ES (designated MCV30) debuted in July 2001 for the 2002 model year.
11вопросов Показать все
Es300: Brake and abs lights came on
Brake and abs light in my 2003 es300 came on. I have checked the abs sensors and cleaned them, checked my brake fuid and its alright. And brake application works fine. How do i get rid of these lights?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
If you believe there is no problem and you want to reset things disconnect the battery for a few minutes then reconnect. If there is no problem the brake and abs lights will stay off. If it comes back on you may have a problem and get it checked by a mechanic.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Ok. Will try it and revert. Thanks
из
Добавьте свой ответ
Brailo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 22
За всё время: 867
