Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624вопросов Показать все
Issue with external monitor when connecting mini DisplayPort to DVI
Hi,
I recently bought mini DisplayPort to HDMI, DVI and VGA adapter.
The problem is with my Mac, when I connect a VGA cable to this adapter I’m getting a picture on external monitor.
But, when using DVI cable I don’t get a picture, or picture shows for a few sec and then on external display I see like white noise (this depends on the monitor, tried with 2 DELL monitors 23” and 24”).
Also, I tried the adapter on my Mac Mini and everything works fine, no issues with DVI port. I did not use HDMI port since my displays does not support it, They only offer DisplayPort, DVI and VGA.
Does anybody have an idea what could be a problem or how to solve it?
Thanks, Svarog
Это хороший вопрос?
Оценка 0
2 Комментариев
Please give us a link to what you bought
из
It took me some time to find the link:
https://www.dx.com/p/cwxuan-mini-display...
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Frankly I’ve never seen a adapter that cheap. You are lucky it works with the VGA. I wouldn’t expect much more from something this cheap.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
svarog будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 460
