Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624вопросов Показать все
How can I fix CPU/GPU temp over 120 C?
My MacBook is broken! It’s CPU/GPU is showing temp at:
So I gave it for unofficial repair the guy said that he had replaced the GPU with another one but no effect the temp is still high and it is hanging with kernel task over 300 % and now its audio is also broken
So, I deleted the Intel hd 4000 kext driver
MacBook Pro running fast but now no GPU is there app are behaving with glitches …
But Mac is working with no sound etc.
Is there any other sensor for GPU which need to be corrected
Please help
Это хороший вопрос?
Оценка 0
1 Комментарий
Your systems specs:
13" MacBook Pro Unibody Mid-2012
Here's the 15" models:
15" MacBook Pro Unibody Mid-2012
Note the differences with the graphics services these two series offer.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Somebody replaced the GPU - really? That takes some very high dollar equipment!
See time 2:30 of the video
https://www.youtube.com/watch?v=vGfKKL6-...
Here’s what it really takes to do this:
https://www.youtube.com/watch?v=Ho2W902s...
How much did they charge you for this service? Especially as it did not solve the problem.
The first thing I would check is for a leak in the heat sink. You can usually spot and oily type of stain on the crimped end of the heat sink on the logic board.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Some are really shameless..replaced the GPU..sure, I can figure that..
из
Please give us the web address of this this repair shop so we can look them up.
из
First your system does not offer a separate dedicated GPU! Only the 15” models offer it.
Here’s a view of your logic board:
I’m not sure what the person who worked on your system did but replacing the CPU/GPU is really not doable without the correct gear. Swapping out the chip from another board doesn’t make sense. Getting the chip is just not possible as Intel only sold canes of 25 chips and no longer available from Intel or local suppliers. If the CPU/GPU where truly bad I would have just replaced the logic board.
So let’s start with the basics I would have done. First cleaning the fan & system of dust build up. I would have also replaced the HD SATA cable (yes high temp issues are often related) MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable. Make sure you apply a strip of electricians tape in the uppercase and use a Bic pen ink tube or bamboo skewer curl the cable so you don’t crease the corner bends following this guide MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement
Next given the systems age I would have cleaned the old thermal paste and applied a fresh coat (Arctic Silver) I would have then monitored the heatsinks ability to move the heat using a non contact thermometer as the system warms up. Depending on what I see the heatsink maybe bad MacBook Pro 13" Unibody Mid 2012 Heat Sink Replacement
Monitoring your system is important but the level of information is also important. I’m more interested in high water marks and logging which this app won’t show you. Seeing things in a more graphical view I also think is better like how TG Pro works.
Lastly, you need to undo the damage you caused by removing the kext file, hopefully you can place it back other wise you’ll need to delete the system folder and install a fresh OS. I’ve had issues after someone has pulled a kext file trying to just re-install the OS on top.
As far as the sound we’ll need to first get this far before we look into it.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Изображение
Продукт
$34.99
MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Изображение
Инструкция
Сложность:
Легко
10 - 25 minutes
MacBook Pro 13" Unibody Mid 2012 Heat Sink Изображение
Инструкция
Сложность:
Сложно
45 minutes - 1 hour
Оценка 2
Добавьте свой ответ
Jamesraikikon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 142
