Logic board appears to be stuck to case
I am following iFixit repair guide for replacement of upper case for this machine. I am at the point (step 24 and 25) in MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Upper Case Replacement
The logic board is loose but something underneath it is holding the logic board from lifting enough to get at the microphone loose.
But the point that is stuck is right near ports between RJ-45 and USB port. I don’t want to break the board by applying too much force to pry it out. Is there anything else I should be aware of that isn’t in this repair guide?
Thank you;
JK
Это хороший вопрос?
