Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494вопросов Показать все
Can I buy OWC Aura Pro X SSD / 1 TB and use it externally
Hello
I have two questions
1-If I want to put one OWC Aura Pro X SSD / 1 TB internally on my MBP Mid 2014 , how to format it before install OS and all my files on it ?
2- can I take one OWC Aura Pro X SSD / 1 TB and put it on OWC Envoy Pro External SSD Enclosure (Mid 2013 to Mid 2015 Macs) for use it as an external ssd on my MBP Mid 2014
thanks in advance
jaime
Это хороший вопрос?
Оценка 0
1 Комментарий
Thanks MacHale
I just bought both
when I get the parts on hands i will try to follow your advice
thanks ,again
из
Добавить комментарий
1 ответ
Выбранное решение
Just plug it in externally, use disk utilities from the original disk to format it and then install a system on it. Now use Migration Assistant to move your Apps and user data.
The format you use will depend on the operating system you intend to use. APSF if Mojave or High Sierra; GUID if using a lower system. Boot from the new drive externally by holding down the Option key and select it.
If it is running fine you can now exchange it for the original internal drive and use the old drive in the enclosure.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Jaime Salazar будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 104
