The Asus Zen AiO Pro Z240IC is an all-in-one desktop computer known for its 4K, ultra high definition screen and one terabyte Hard Drive. With plenty of processing power and memory, the device received the PCMag Editors’ Choice award in 2015.
22вопросов Показать все
Display not working after Motherboard Installation
I purchased a replacement motherboard (v 1.4) and have installed this according to the procedure shown in this guide. The motherboard powers on, the fan spins as it should but there is no display showing. I have tried reinstalling the RAM and re-booting but no luck . The display still does not show.
Does you have any suggestions? I am at a loss at the moment.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Its turned out to be a faulty motherboard. I bought a replacement from Alliexpress and it has worked perfectly. Got into the Bios 1st time round without an issue. We think that the graphics card on the old motherboard was the problem.
Thanks for all the help.
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
If you haven’t done so already, look through the ifixit guide again and recheck all your ribbon cable connections.
Does your model have the HDMI port? If so try connecting to another monitor or TV to see if you get anything.
Оценка 1
2 Комментариев:
I have checked all the ribbon connection cables. I have even tried connecting to another monitor. It is probably something simple but at the moment I can’t work it out.
из
So you see nothing on the screen, not even able to get into BIOS?
из
Добавьте свой ответ
Manjinder будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 378
