Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548вопросов Показать все
White Screen Startup No empty Folder
I have seen another post about this but it looks like it fell apart. There was no good result in that one so lets get s good one in this one.
Boots, Chimes and engages all devices (fans, dvd, speakers).
Lights up all four LED on board.
Continues to run but never shows apple or empty folder.
The following have been done with no success.
-Replaced HDD
-PRAM reset
-Commnd+C restart
-Safe restart
-load OSX disc and attempt hardware test
-Replaced Memory
-Swapped a good screen into it
-tried to use a 2008 20" iMac board but got a strange repeating chime... dont think it liked a board from another model.
Now I need some other logical thoughts.
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hook it up to an external monitor and see what you get.
Был ли этот ответ полезен?
Оценка 2
Hello, i got the same problem and hooked an ext. monitior. and there is an blank dekstop were i cant't do anything, but only create a folder and look at it.
Jan
Оценка 0
1 Комментарий:
This is a different type of problem. Please start your own question and elaborate on being able to create a folder. Do you also show a curser?
из
Добавьте свой ответ
Erik будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 663
