The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
90вопросов Показать все
I dropped mycharge 3 in the ocean yesterday
It worked completely fine without trouble when I got it out of the water but when I got home I turned it off and put it on the charger. Later on (this morning around 7:00) it would stay on, didn’t make any noise even when I used the Bluetooth button to connect it with my phone it wouldn’t work and it still doesn’t make noise even when it turns on. What do I do and or how do I fix it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@james1243 possibly a short circuit or otherwise damaged component from the water. For now, you do want to stay away from charging it or trying more often to turn it on. That could make a bad situation worse.At minimum go ahead and disassemble everything JBL Charge 3 Motherboard Replacement and visually check the motherboard as well as other connections etc. You do want to clean everything with +90% isopropyl alcohol and a soft brush. After you clean it replace the battery and the reassemble and reevaluate.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
James Correia будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 8
За всё время: 102
