Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
Wifi and Bluetooth not working after water damage
I dropped my iPhone 4 in coffee. I powered it down and rinsed it real good with water. I of course removed the sim and battery. I dipped the phone in 99% alcohol. I thought this was best since I use cream and sugar in my coffee. Then did the rice thing to dry it out. It worked great except the screen is a little cloudy but that seems to be getting better so no worries there. My issue is that now the Wifi is grayed out and my Bluetooth doesn't work either. It looks like it tries to go to the 2nd screen on Bluetooth but the little wheel just keeps spinning. I did a restore and that didn't help. Do I need to replace the antenna? I just got the phone 6 months ago so I'm not due for an upgrade. I think it is still eligible for the Out Of Warranty replacement with Apple but I wanted to try a less expensive solution first.
Это хороший вопрос?
Оценка 5
Добавить комментарий
9 Ответов
Наиболее полезный ответ
Trust me guy's, before you replace your phones you should disassemble your phones and give them a real liquid damage treatment, I do this to Iphones all the time in my shop and rarely cant bring everything back to life, the Rice thing is truly a joke, it just doesn't work, here is a guide for an I 3 but use the same methods on your phone,Repairing iPhone Liquid Damage, and here is a guide o teardown your phone, iPhone 4 Teardown, if your not a DIY person I would recommend paying a shop to do it, it shouldn't cost much, I charge a flat rate of $30, good luck, If this Answer is helpful please remember to return and mark it Accepted.
iPhone 4 Изображение
Инструкция
iPhone 4 Teardown
Сложность:
Модерировать
iPhone Изображение
Инструкция
Сложность:
Сложно
1 - 2 hours
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
After I cleaned the logistics board everything started working again except the WiFi. Any suggestions?
из
the $199 replacement fee is an insignificant price to pay compared to how frustrating troubleshooting water damage on an internally delicate machine like the iPhone 4 can be. A ruined antenna would not cause the iPhone to gray out the icons like that, you would just notice diminished function. It's more likely that the chipsets that control those functions are damage.
Оценка 0
It seems like the Chip that covers both functions is "fried" so you have two options change the logic board or change the phone totally with out of warranty deal with Apple!
Оценка 0
Hi, this is Francesco from Italy
I've the same problem too: water = no wifi, no bt.
Have you solved at the end?
In that case please help me
Thanks in advance
Оценка 0
4 Комментариев:
Go to Settings and turn Airplane Mode and Do Not Disturb ON
Power down and wait 5-10 minutes
Power up
Go to Settings and turn Airplane Mode and Do Not Disturb OFF.
Let me know if that worked. John.
Riverp5b@hotmail.com
из
Roverp5b@hotmail.com
Not river!!!
из
It didn't work, but thanks anyway.
из
Totally Worked! After I turned on Airplane Mode and Do Not Disturb I also put my phone in a bag of rice and let it sit for a few hours. Just for luck. So not sure what exactly fixed the issue. But, I took it out of the rice and turned off Airplane Mode and Do Not Disturb and now my phone connects to WiFi. Cheers for the help!
из
the answer is your mom
Оценка 0
I dropped my iPhone 6 in a hot tub for 1.5 seconds. I turned it off immediately and wrapped a towel around it for another hour before I had to make a phone call. The screen was touch glitchy and the call mic(the speaker for your ear when having a phone call) didn't work. I then turned it off and on about 3 times within a 6 hour period. I finally turned it off for about 9 hours in a dry rice bowl. I woke up that morning to see that my call mic works! Now my only problem is that my wifi antenna is very weak. I need to be within 0-10 feet of my router for it to pop up/connect. Is there any way I can make it stronger? Do I need to replace my logic board or just the antenna? It's been 2 days after the incident and it's still happening. Thanks! Tweet me if anyone has a fix @andttias. It'd be greatly appreciated!
Оценка 0
1 Комментарий:
I too am having issues, but only with wifi, and yes I wet my iPhone 4S by sitting in the sea on a beach, not realising it was in my pocket, perfect hot day so me and iPhone dried off on the hot sand, on a mini sunbed i made up, bless:), all came back to life, with no issues, except wifi keeps dropping on and off, Bluetooth works fine, any help, thanks, now bought iPhone a little wetsuit:)
из
Omg, I had that problem with my iPhone 6, but thanks to John, it’s fixed.
Оценка 0
I kept my smart phone le x526 in flight mode and do not disturb mode for few minutes and then unclicked both , my Bluetooth started working fine. Earlie water had entered my phone and Bluetooth was not working, getting grey. Thanks River for suggesting a good idea.
Оценка 0
Did you check for any new software?
Оценка 0
Добавьте свой ответ
Beckie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 13
За последние 30 дней: 64
За всё время: 54,010
