The HP Compaq 2510p, model number "GM651AW" and was released June 2007. It features an Intel Core 2 Duo ULV processor and 12.1 inch display.
My laptop won’t charge.
My laptop won’t charge and displays a steady white light and a blinking yellow light on the charging led. Whenever I take out the battery it still won’t turn on. I even tried replacing my charger although I don’t know if the one I replaced it with is compatible with it although there the same brand. I need help on fixing this cause it’s not even my laptop but my sisters laptop and I have not told her it isn’t working as yet.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
@romainedwyer check your AC adapter with a multimeter to make sure that you have the right voltage. The brand is irrelevant for as long as the specs are the same. For this laptop you will need a 65Watt 18.5V 3.5A power adapter. Let us know what you have.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Romaine dwyer будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 182
