The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150вопросов Показать все
Where to buy small digitizer FPC connector 36 pin?
Hello,
Can you guys please share companies/links where I can buy small digitizer FPC connector 36 pin for iPad 6th gen (2018)? @refectio @arbaman
Unfortunately I don’t have any donor boards, and this is the only company I found so far but shows out of stock…
https://microsolderingsupply.com/index.p...
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
The iPhone 6 Plus LCD FPC looks like a match. Can let you know if it works when I know.
EDIT: IT WORKS! The iPhone 6 Plus LCD FPC is confirmed to work in place of the small 36pin iPad 6 Digitizer Connector. Bless Apple and their cheap recycling hearts.
Был ли этот ответ полезен?
Оценка 2
Наиболее полезный ответ
It actually looks identical to the LCD connector on the iPhone 6. Apple does reuse FPC’s for different purposes on different devices.
Оценка 4
3 Комментариев:
Interesting - they do look identical, but the number of pins do not seem to match. I did not know Apple reuses FPC on different devices, learnt something new today :)
из
It's a 36 pin connector so it should match up nicely.
из
из
Добавьте свой ответ
Gorilla будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 587
