AC blows warm air when idle.
Why does my AC blow warm air when sitting idle, but cool air when driving.
Это хороший вопрос?
Это хороший вопрос?
The problem is most likely low freon, overheated engine, or condenser fan.
Check your freon levels. If low, recharge.
Does your engine continually run on the hotter side? If so, then check your coolant levels.
Otherwise, the issue is most likely the condenser fan is not working. When you are driving, there is sufficient air passing over the condenser to cool it, but when you are at idle, the fan is the only thing to move the air.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 14
За всё время: 2,546
