Whirlpool Dishwasher starts after keeping the door pressed manually.
Hi, I have an Ikea whirlpool dishwasher. It had a free fall door because hinge string was broken which I replaced. Now, it starts when I keep the door pressed manually. It runs for sometime even if I stop pressing the door but stops after sometime. If I presss the door again then it starts again but stops after sometime if I stop pressing the door. I already open the door and checked all the wires and everything is connected. I also cleaned the area for clogging and anything stopping the close the door properly. Could it be door latch or something else need to be replaced?
Thanks
Vikas
Это хороший вопрос?
3 Комментариев
I need your model number to be able to locate parts.
из mayer
Hi Mayer, Thanks for your reply. It's integrated whirlpool from Ikea. I can't see actual model details. It has service no. as 854586701001 and serial no. as 990740072630.
из Vikas
See if you still have the operators manual, iy will have the model number. I can't find the correct parts without it.
из mayer
