The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Gas vapor smell
i have a chevy cavelier and when its been running .like i will go for a ride the weather is hot no a/c but i will stop at a store .after getting back in the car i will start it and sometimes smell a gasoline smell? could you tell me why. there are no gas leaks on the ground. none any where
Это хороший вопрос?
Счет 3
2 Комментариев
i smell gas but no leaks 2001 Chevy caviler
из
Mine is smelling like gas, and has miss/sputter occasionally.. And went dead when I came to an abrupt stop at a stop sign, but it cranked back up immediately, with no problem.. Other that that, it runs great.. It’s an 05 sunfire 2.2. Anyone know what it might be?
из
Добавить комментарий
7 Ответов
Наиболее полезный ответ
Lynn, I would look under my car after I shut it off to see if anything is dripping. Also check your tail pipe and see if the smell is coming from there. Next I would take it to an AutoZone and get a free computer diagnostic to see if it is reporting anything.
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
Wouldn't hurt to check. +
из
Этот ответ изначально был на другой вопрос.
I believe the charcoal canister is responsible for dealing with gas vapors Check your EVAP vent valve. It controls fresh airflow into the EVAP canister. It may be closed, should be normally open. Definitely check all hoses that go to your charcoal cannister and make sure they are working and not cracked and/or loose. You may be due for a canister replacement and an evaporative emission system cleaning. Good Luck and let us know if any of this helps you out.
Счет 2
1 Комментарий:
In both my 2004 Caviler and my 2005 Colorado P/U I get the same occasional odor. Problem only seems to happen with gasohol in the tank. Wonder if the alcohol is somehow passing through the filter easier? When it happens it only happens when starting and just for a few seconds. +
из
If there are no spills on the ground than that means any leaks that might be present are very small, and the gasoline that leaks out is evaporating, which is what you're smelling.
Answers.com has a very good reply to a similar question:
http://wiki.answers.com/Q/Why_would_a_ca...
Счет 2
Check the gasket on the fuel fill cap. They crack with age and may be allowing vapors to escape as the fuel expands in the tank. This can also cause the check engine light to come on.
Счет 1
Could be a fuel rail leak on the line that supplies gasoline to the carb. you may not see liquid as it will evaporate on top of the hot intake.
Счет 0
1 Комментарий:
doesn't have a carb
из
take oil filler cap off and check if petrol smell is there. if there is petrol in oil then big problems will come ( oil will be more fluid and not pump everywhere, leading to big end failure). might be leak in petrol pump.
Счет 0
Mine was a fuel pressure regulator fpr for short. I had a couple of cups of raw gas in the air intake, the bad fpr cause fuel to go in the air intake which cause a gas smell. $70 at O'Reilly.
Счет 0
Добавьте свой ответ
lynn буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 22
За всё время: 15,403
