New Battery Is Charging & Recognized, Won't Run on Battery
Just replaced the battery in the MacBook Pro 13” with a new one from iFixIt. The battery shows up at 78% and is charging, I’m watching the mAh increase. The LED on the charger shows orange, as in charging. If I disconnect the power supply the computer won’t run on the battery alone, it must be plugged in, even though it has a charge. Any ideas?
Это хороший вопрос?
4 Комментариев
Lets get a better idea on what's happening. Install this gem of an App CoconutBattery Take a snapshot of the main window and post it here for us to see Adding images to an existing question
из Dan
Thanks Dan, I uploaded that.
из Greg Dietrich
Well the battery does appear to be in good condition as you implied.
So that part of the circuit is working so if you now pulled the MagSafe connection he system would just shutdown on its own in a few seconds. Is that correct?
из Dan
@danj Right, if you pull the MagSafe it powers off immediately. Battery has charged all the way up now thouhg.
из Greg Dietrich
