Выпущенный 16 сентября 2016 года смартфон нарекли iPhone 7 Plus. Вышло несколько моделей нового устройства: A1661, A1784, и A1785, а также можно было выбрать между версиями на 32, 128 и 256 Гб встроенного накопителя. На выбор можно было приобрести золотой, розовое золото, серебристый, Jet Black и (PRODUCT) Red оттенки корпусов.
1365вопросов Показать все
iPhone 7 Plus stop charging at 3% after replacing new battery.
My iPhone 7 Plus battery just got replaced with the new one. I forgot to put ‘sticker’ to prevent the battery from moving. after few months the old battery stoped working, I even cannot charge it at all.
After that I replaced it with a new one. It stop charging at 3%.
I opened battery setting, it didnt show at all about battery capacity.
And then I also tried 3uTools, and I cant read the capacity too.
Anyone have a solution?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
There are some tiny components surrounding the battery connector. One of them allows the battery charge state to communicate with the CPU/Charge Circuit. It’s not uncommon to accidentally dislodge components when disconnecting the battery and this is a typical “pry damage” symptom.
Look for R2201 in the image below.
Был ли этот ответ полезен?
Оценка 3
4 Комментариев:
How should I fix this?
Are you suggesting me to buy a new dock connector replacement?
из
No, you need to determine if the highlighted component is still there. If it's missing, it must be replaced which would require a micro-soldering repair.
из
Hi, I didnt quite understand what is actually "battery connector". I looked at the battery connector on the flex cable and in the motherboard, on my eyes the diagram given is not matching with the one I see. SO maybe I looked at the wrong one
из
FYI: I got a replacement batt, now it charges only till 13%
and then it wont charge againt till it droped 1% and the phone restart by itself
из
Have you tried other new battery? maybe the battery you replaced was faulty.
Оценка 0
2 Комментариев:
No, I havent. I will send it back to the seller today. I hope its the battery
из
Just try to test your old battery if that charge more than the percent you need, if that goes up means you got a faulty batt.
из
Добавьте свой ответ
Henka Gonzalez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 314
