2015 MBA not recognizing any drive
2015 MacBook Air went through security at the airport, now is not recognizing harddrives (flashing question mark on startup, not recognized in Disk Utility after using Command + R). Initially thought SSD was shot, but tried plugging it in to another MBA and it was recognized.
Any ideas? Cable? Logic Board?
Это хороший вопрос?
2 Комментариев
You did hand carry it onboard - correct?
Did you have your system in sleep mode Vs fully powered off when it went into the scanner?
Are you sure the system was not dropped or banged somehow?
из Dan
My wife put it in checked baggage (I know...) It wasn't powered off. The damage definitely could have been physical.
из Darryl Davies
