The 2005 version of Volkswagen Beetle is the upgraded version of the 1998 edition, which obviously came with a large number of improvements and advanced features.
11вопросов Показать все
How do I get AUX input out of the body of the car?
The AUX input has been knocked inside the body on the inside of the car. Does anyone know how I can get it out?
Это хороший вопрос?
Оценка 0
3 Комментариев
So if you fit the plug in it will toggle side to side or it goes in but you don't feel the detent?
из
Hi Dan, the AUX input used to be where that black hole is now. The input was pushed inside and I'm not sure how to get it out
из
We’re is the aux located ?
из
Добавить комментарий
2 Ответов
Выбранное решение
This YouTube video shows how to take the center dash off for the Volkswagen Beetle 1998-2010.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Hi Joshua, thanks for this. I'm not sure I'll be able to get to where the AUX cable is via the area where the centre dash is though
из
Ryan,
You are going to need to remove the center dash just to put the AUX port back in. Once you have the dash off, you can look and see where the port has fallen. This will provide you with more room to work with rather than trying to go in from the bottom.
из
It maybe cracked so the part is not secured or the socket maybe broken. The test I had offered to you would give you a clue which way things are likely to go.
If you can wiggle the plug side to side the socket is not mounted to the panel.
If you don't feel the detent (comparing to another device) then the socket has failed.
из
Dash is usually easy to get off .has screws or clips holding it in place. Check u tube for your car model and then replace jack and glue bk into place.
Оценка 0
Добавьте свой ответ
Ryan Ball будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 74
За всё время: 6,289
