Seagate external HDD Drive 8TB Model#: SRD0PV1 Models of differing size likely have the same casing.
4вопросов Показать все
External Hard drive not showing up?
So I recently dropped my external hard drive on accident. I know I know… theres my first problem right.
Well I thought there might still be a chance that it works. So I plugged it in to my computer and the light on it came on as well as the sound that the computer makes when I normally plug it in.
The issue is though that it doesn’t show up on my computer anywhere. The weird thing is that I can still eject it like I normally would with the eject button… Is there anything I can do to fix it or to get my files? I have them backed up for the most part, there are only a few that I don’t have.
Also I’ve looked up other questions like this and a lot of them say there is some mysterious ticking noise coming from the harddrive but mine doesn’t have any noises coming from it.
Any help would be appreciated :)
Это хороший вопрос?
Оценка 2
1 Комментарий:
I am fix the hard drive but in my computer the external hard disk is knot showing and hearing the beeping noise from the hard disk kindly suggest me how to fix the issue
из
Добавить комментарий
2 Ответов
HDD’s are very fragile! SSD’s are structurally much stronger! You may want to look at getting one.
Sadly, if the drive was powered the heads likely crashed into the platters either ripping them off or damaging the patters. Think how an old style record player would damage the record when the needle jumped across the groves which then kills the record. Here the needle is also ripped off as well.
At this point there is nothing you can do and in fact anything more you are likely to do will just damage your drive more! This is where a data recovery service is needed as they will open the drive in a clean room and fix the drive enough so the data can be salvaged.
So is the data you have on the drive that important or do you have a backup on a second drive?
Был ли этот ответ полезен?
Оценка 0
Hi, maybe you can troubleshoot the computer to fix the external hard drive not recognized issue, here are the steps, hope it can help you:
1. Type “troubleshoot” and search and open it.
2. Click on the option “Hardware and Devices”. This option will find and fix problems with devices or hardware. It can solve the problem when an external hard drive cannot be detected, recognized or showing up when used in Windows 10.
3. After you click “Hardware and Devices”, click the “Run the troubleshooter”.
4.After the scanning, the system will list all of the fixes for you. You can click apply this fix.
5.Click next to restart your pc. Restart your PC so you can finish installing the driver software and other updates related to the hard drive and other devices.
Hope you can fix the issue soon.
Оценка 0
1 Комментарий:
Would you mind telling us WHERE to type troubleshoot ? Why wouldn't I just go to it in control panel. Are you trying to confuse people
из
Добавьте свой ответ
RaeAnn Bucher будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 14
За последние 30 дней: 34
За всё время: 1,937
