Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210вопросов Показать все
Screen keeps popping back off.
I replaced my bloated battery & I’ve tried 2 new pressure sensors with adhesive. The adhesive is sticking to the watch but won’t stick to the back of the screen. Is there a trick to get it to stick? Or do I need another adhesive? It will stay on for a few hours & pop back up
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I dont like using super glue. I know it’s mostly not popular at all to use, but if you get a gorilla glue micro pen or some type of super glue with a controlled flow use just a tiny dot in the corners and one half way between each corner. The iWatch screen is very light, so a little bit will hold it. I’m not sure why, but I have the same issue you are having about every 10th iWatch I fix.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Adam будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 142
