LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
46вопросов Показать все
Can you install an iPad Air 1st Gen logic board into a 5th gen tablet?
I have an LTE 5th generation tablet with a damaged logic board. I was wondering, since these two tablets are essentially the same, if you could install the logic board for a 1st generation into it, wi-fi or lte?
Это хороший вопрос?
Оценка 0
7 Комментариев
Why on earth would you believe these two are “essentially the same”?
из
Are you asking about a first gen. iPad Air maybe ?
из
@tomchai You know what...I realize I meant to write iPad Air 1st Gen. So, I made a mistake. But I'd guess you know nothing about mistakes since you're so are so perfect and above everyone else.
из
@arbaman Yes, you're right. I meant iPad Air. Sorry about that.
из
To be honest I wouldn't be able to tell you this because I have never had the situation where I needed to do so.
из
Показать 2 больше комментариев
Добавить комментарий
1 ответ
Наиболее полезный ответ
The power ports are different, so no.
UPDATE
I have no idea on the iPad Air, sorry.
iPad Air LTE Teardown
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I apologize. I meant iPad Air.
из
Добавьте свой ответ
Jenny Lawson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 130
