Replace the small black tap on the back
Gear Sport, Blue'''
MODEL NUMBER: SM-R600SERIAL
The black tap on black is gone. Need a replacement? Can anyone fix or can I order this part? Thx
Это хороший вопрос?
Gear Sport, Blue'''
Это хороший вопрос?
This is the only replacement that I could find.
https://rounded.com/samsung-gear-sport-s...
If you do not have one, you will need a tri-wing screw driver. You will also need a splunger or a guitar pick or playing card to pry the back open once you remove the screws.
Here is a simple tear down guide for the Samsung Gear Sport.
Hope this helps. Good luck.
Был ли этот ответ полезен?
This is wonderful..thank you, thank you, thank you! I have ordered the back and screw driver and I am sure I will check out the guide once they arrive!
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 186
2 Комментариев
It's not clear what part you are looking for. Can you provide a picture showing more detail? Thanks.
из Joshua Freeman
Picture was added for clarity.
из Lyn Hardway
