Fuel in motor oil
I got old ford tractor skip loader and I replaced injectors but I'm getting fuel in my motor oil
Это хороший вопрос?
Это хороший вопрос?
The number one cause would most likely be leaking fuel injectors. ... When a fuelinjector is stuck open, the fuel will flood out. Gasoline will definitely get into the oil when this is the case. If the fuel pressure in your car is too high, that may cause gasoline to get into the engine oil.
Был ли этот ответ полезен?
I put new injectors how can they. Be stuck and I took them out not one was wet
There's no way it can be injectors that's why I'm asking you all
Read the rest of my answer.
За последние 24часов: 4
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 156
