Второе поколение iPhone. Модель A1241; 8 или 16 ГБ памяти; с черной или белой задней пластиковой крышкой. Ремонт проще, чем первого iPhone. Требует отвертки и инструментов для вскрытия.
1158вопросов Показать все
Вопрос закрыт
Screen is completely white
My iPhone 3G got wet and I dried it for days in a bag of rice. Eventually it started working again and I managed to have iTunes recognize my iPhone once more. I restored it and now the phone works again. Calls, texts etc. all come in, but the phone now has a bright, white screen. Underneath I can make out the clock and all the symbols, and it recognizes my finger gestures instantly, but the screen remains bright white with gray horizontal lines/flickerings. I opened up my iPhone yesterday and checking the number 1, 2 and 3 cables didn't resolve the issue. Would this be an LCD problem or can someone tell me what to do?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Try replacing the iPhone 3G display to try and solve the issue.
Был ли этот ответ полезен?
Оценка 0
I have the same issue with my iPhone. It has been dropped on the ground and then dropped in water. I replaced the LCD and digitizer but the screen is still bright white. The phone still works, I can make calls and use the touchscreen. The only problem is that the screen is completely white. If I hold the screen at an angle I can see the image which is very faint.
The problem can't be in the LCD. I'm wondering if anyone has an idea on how I can try to fix tis.
Оценка 0
1 Комментарий:
The logic board is most likely fried where there LCD connects to the board.
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 1,606
