Смартфон был выпущен 26 октября 2018 года с разными модулями связями и количеством SIM-карт. Модели A1984, A2105, A2106, A2108 были доступны с GSM или CDMA/eSIM, nano-SIM или dual-SIM. Объём памяти варьируется в пределах: 64, 128, 256 Гб. И, конечно, iPhone XR увидел свет в различных оттенках корпуса: черном, белом, синем, желтом, Coral и красном.
Why am I having touch issues after screen replacement?
I have replaced 2 separate iPhone XR screens lately. Both repairs I’ve followed very well instructions and done everything by the book. Both devices have started acting up after repair. My biggest issue is the touch screen not responding, ghost touch, clicking when nobody’s touching it. I’ve tried putting other screens on it and still happens. What could be the cause? Let me know if you need additional info. Thanks
Это хороший вопрос?
Счет 8
2 Комментариев
From my experience the displays from fixez.com do really well.
из
It happened to me to for my iPad Im typing on it now and it’s hard to type I went to a phone repair place and didn’t work now I can’t play games normally:(
из
Добавить комментарий
4 Ответов
Выбранное решение
The screen has touch sensitively variations as a result of manufacturing tolerances. Apple has a machine to calibrate individual screens, you don’t. So you can only keep swapping screens until you find one more ore less matches with your phone.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
@tomchai ok, this makes sense. So did the just start doing that with the iPhone X line? I know I haven’t ran into this issue with any older devices.
Is there anyway to mess with settings?
из
Calibration is present since always, but starting with iPhone 6s, 3D Touch May need greater attention to calibration and starting with iPhone 7, screen sensitivity from various suppliers drift away significantly, requiring calibration or keep trying your luck to function properly.
из
I have just replaced mine , I purchased a donor off eBay to hold my mother board as my screen was cracked and so was my back however it seems the touch Is not responsive on the bottom half
Счет 0
1 Комментарий:
You got it fixed somehow?
из
I also faced the same issues before but i solved by invest 1 hour’s time.iPhone XR has so sensitive flex with some force activity while removing makes that issue see carefully the edge of Fpc might be tore makes that issues. Clearly observe you find the solution.
Счет 0
1 Комментарий:
What is the edge of Fpc?
из
I’m on iPhone xs, i went to see apple when the left side of my screen stopped being responsive, they wanted £300 to fix it, I got a screen kit from ifixit for £165.99 but ghost touch started after that, i’m now on my 2nd ifixit screen and still getting ghost touch, can i take it to apple and get them to calibrate it?
Счет 0
1 Комментарий:
iirc, Apple will only replace screens for a ridiculous price and does not offer calibration by itself. Aren't they great?! That being said, many repair shops have the equipment to calibrate screens on their own. Maybe try calling one near you and ask if they're able to do it?
из
Добавьте свой ответ
mike буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 31
За последние 30 дней: 111
За всё время: 22,362
