Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
Help with Glass only screen repair (Not lcd repair)
I have done many repairs before so I am not a total noob however I have just recently attempted to do a glass only screen repair on an iPhone 7, I got the glass of perfectly without problem but the glue that remains on the lcd seems impossible to get off without breaking the lcd even though im using 99.9% isopropyl alcohol. Any tips on how to overcome this? thanks in advanced.
Это хороший вопрос?
Оценка 0
3 Комментариев:
Just use the adhesive removal tool it's a heated scraper that cut through the glue.
Changing just the glass without all the tools required to do so sure seems like a total noob thing to do lol
из
I have been trying to use that and i feel like I’m having too scrape way too hard to get any adhesive off
из
Is it a handheld one or a proper one??? Make sure its heated enough... it should all just come off fairly easily, there is a chinese debonder liquid available that dissolves the glue as well but u have to be careful with it as it gets between the backlight if u havent removed that...
из
Добавить комментарий
1 ответ
It could be that you are trying to take the polarizing layer off in which case you would have to fully remove it and buy a new polarizing layer. If not, try using acetone.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Haris будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 56
